streapadair
Message 1 of 3
Re: Cancelling caller redirect. How ?
Call Diversion and Caller Redirect are two different features - the first is easy to cancel, the second impossible, or so it seems.
I've been trying to get rid of Caller Redirect (c£30 per quarter) for 5 years now, without success.
I hate BT.
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Hi @streapadair,
Welcome to our Community.
I am sorry to hear about the problems you've had trying to get it cancelled. I've sent you a private message so we can check your account and help get it removed.
We will do all we can to help you.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
-Richie-
Expert
Message 3 of 3
For future reference :
To remove call diversion you want the Loyalty or Value team.
To remove caller redirect it's the billing team.
