Message 1 of 3
Re: Deleting numbers from call blocking List
On the BT4500, you can only store 10 blocked calls numbers. How do I delete them????
2 REPLIES 2
Message 2 of 3
View the calls list.
Then delete the entry for the blocked number.
Moderator
Moderator
Message 3 of 3
Hi @NODDYNODSVILLE check out page 27 and 28 in the user guide
1. Select Menu, scroll to Call control and
select OK.
2. Press to display Block calls and press OK.
When you enter the block
calls list you can also edit or
delete numbers you’ve stored
previously by selecting Options
and then pressing VOL ^ or Calls v
to display either Edit number or
Delete number and pressing OK
