petermann3
Message 1 of 4
Re: Gold / Silver issue
Hello John
Im trying to contact you with the same issue but i can't seem to find the link contact mod anywhere.
do you have email address please?
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Hi @petermann3 Welcome to the forum and I've moved your post to create your own thread as that's the best thing to do. Can you confirm that you are a BT Retail customer for your phone line and that your address is listed on the Royal Mail webiste.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
petermann3
Message 3 of 4
Hello John.
I'm currently with talk talks, as BT own the line does that make me a BT retail customer
Moderator
Moderator
Message 4 of 4
@petermann3 No sorry we can't help with any service issues you're having, you will need to contact your supplier Talk Talk directly and if necessary they will raise this with Openreach if there is a problem with the network records.
Community ModeratorNeilO
Kudos”
