Message 11 of 18
Re: Lost landline number during broadband switch - please help?
As @JohnC2  has reserved the number for your case, then I cannot see any issue based on past experience.
Numbers are physically mapped to each exchange concentrator so if people remain at the same address, then they will still be connected to that concentrator.
The initial temporary number will be on the same concentrator, and this is needed to prove the connection. Renumbering is simply a software change which happens overnight once the command has been issued.
It's rather old technology, but it usually works. Renumbering happens every day for various reasons.
Moderator
Moderator
Message 12 of 18
Hi @GMann80  I was just looking to get the call rolling to get the line connected as quick as possible. If you wish to wait then one of the team will be picking up your case shortly and they will give you a call to explain things.
Cheers
John
Moderator-Retired
Message 13 of 18
Thank's for speaking to me today @GMann80  , speak to you again at the weekend.
Matt
Message 14 of 18
Matt
Could you give me a call back please
Gregory
Moderator-Retired
Message 15 of 18
Thanks for taking my call.
Please let me know the order number via SMS once you have been able to place the new order for service on BT.com.
Matt
Message 16 of 18
Matt looks like the connection went through ok yesterday.
Can you give me a call or let me know about the process for securing our old number now.
Regards
Gregory
Moderator
Moderator
Message 17 of 18
Hi @GMann80  thanks for the update. @Matt-S  will be back in the office tomorrow and the renumber looks ok to be completed on Tuesday and he will check and confirm this for you then.
cheers
John
Moderator-Retired
Message 18 of 18
Hi @GMann80,
I hope you are doing well?
Everything should be up and working on the correct number now. Would you be able to check with your dad to make sure this is the case?
I have sent you a private mail to explain the first bill also.
Matt
