racetrack14
Message 1 of 5
Re: My Phone says 'No Line' & is not receiving any incoming or outgoing calls
I have the same problem with my cordless phone but my normal land line phone works fine. Help please
4 REPLIES 4
Distinguished Guru
Message 2 of 5
can you plug the cordless phone into the phone socket that the normal phone is plugged into in case you have a fault on that particular telephone socket?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
kylemorgan
Newbie
Message 3 of 5
I specifically remember replying to this. Still waiting.
kylemorgan
Newbie
Message 4 of 5
exact same issue everything is plugged in correctly doesnt make sense. old analogue phone gets dial tone. these do not.
Message 5 of 5
