Newbie
Message 1 of 3
Re: New BT landline wont ring on calls from 3 or id mobile accounts
Hi @JohnC2. I've the same issue. Switched from TalkTalk to BT and landline now gets calls from outside/others but not from 3 mobile accounts. Grateful if you could help me get this sorted.
Susanne
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Sounds like the number not fully ported across to BT from talk talk. I will get a mod to jump on this post.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Distinguished Guru
Message 3 of 3
Hi @skbrit,
Welcome to the Community. I am sorry to hear about the problems you've had,
We can take a look into this for you. I'll send you a private message with some of the details that I need.
DanielS
