-Pauline-
Message 1 of 2
Re: No More BT Landline?
I have the smart hub 2 and digital voice will not work.  The hub manager says phone Not Configured.  Phone registers but “no voice service on the hub”
5 faults raised to date none closed by me, all the same problem.  3 new hubs, phones replaced....
6 hours on my mobile to BT across 5 weeks!
does anyone know how to get an actual engineer to visit my apartment to fix this???!!!
1 REPLY 1
RobbieMac
Moderator
Moderator
Message 2 of 2
Hi @-Pauline-
Welcome to the Community and thanks for your post!
I'm sorry for the problems you're having registering the handset for digital voice.  I appreciate the time that you've spent trying to get this sorted out.  6 hours is a very long time to be spend contacting us.
You can get in touch with us and we'll get back to you.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
