ARWalker
Message 11 of 29
Re: Really Old Master Socket/Box
Could you explain what 'Star wired' means please?
Message 12 of 29
Extension wiring should be daisy chained via the master socket, your extension wiring is a spur from the incoming cable and will be acting as an aerial to pick up noise or causing signal reflections both of which will interfere with the broadband signal.
ARWalker
Message 13 of 29
Thanks Licquorice, understand you now!
Here are the stats:
Product name:
BT Hub 6A
Serial number:
+084316+NQ71532136
Firmware version:
SG4B1000B316
Firmware updated:
28-Jul-2017
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 2 Hours 8 Minutes 34 Seconds
Data rate:
7.20 Mbps / 13.10 Mbps
Maximum data rate:
14332 / 46640
Noise margin:
10.7 dB / 21.8 dB
Line attenuation:
19.2 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
20546 MB Uploaded / 33124 MB Downloaded
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-C9H3
2.4 GHz wireless channel:
Channel 6
5 GHz wireless network name:
BTHub6-C9H3-5
5 GHz wireless channel:
Channel 44
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:28:9A:9F
Software variant:
Boot loader:
7.33.1
Message 14 of 29
With that wiring do you find that your broadband drops every time you make or receive a phone call  the drops in internet connection are resulting in higher noise margin and lower speed. So sort out the star wiring and connection will start to improve
Message 15 of 29
You could of course just disconnect the white wire which connects to extension and then just get cordless phones
Message 16 of 29
Agree with @imjolly either disconnect unwanted extension wiring at the junction box or regularise the wiring.
Message 17 of 29
@imjolly wrote:
You could of course just disconnect the white wire cable which connects to extension and then just get cordless phones
ARWalker
Message 18 of 29
I think what the plan will be is to remove the unwanted extensions, and only leave the one that is connected to the upstairs LJU box, until I get a local engineer out to replace the LJU.
Does this sound like an appropriate course of action?
Message 19 of 29
Once you disconnect the white wire/cable then you have fixed the problem and connection will improve. Up to you if you want to upgrade the master socket
XRaySpeX
Recognised Expert
Message 20 of 29
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
