ARWalker
Message 21 of 29
Re: Really Old Master Socket/Box
CJT80
Expert
Message 22 of 29
@ARWalker wrote:
Thanks for the speedy response.
My Dad’s broadband speed is around 12mbps when he was given a minimum speed of 32mbps.
I did a BT Wholesale test and it’s varying in speed between 12 & 14mbps.
Clearly your Father has Fibre (FTTC) which accounts for the speeds he should be getting. Based on this post, and your recent included picture, you are experiencing very slow speeds.
I would (as the others have suggested) either:
A: Gently remove the extension wiring, with the modem/phone removed from the other socket, and then reconnect the modem/phone let it re-sync and then see what speed you get.
B: Find a local engineer, ex BT they are usually called, and ask them to do the work for you, and pay the cheaper costs.
C: Get Openeach to do it for you, and pay £130.00.
Any chance of seeing the Master Socket as well?  Just curious.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
ARWalker
Message 23 of 29
Hi. The ‘Master Socket’ is as per the 1st picture, which is then linked to a bog standard LJU upstairs.
From speaking with my folks, it turns out that when the line was put in back in the late 70’s, they shared a line with another house, where they could pick up the handset and could hear other conversation going on in the village.
Thankfully this afternoon, Openreach called as I had raised a fault with BT back in early December.  After some investigations, it turns out that there is a fault where the box attached to the pole (where I assume the lines are wired off), is ancient - at least 30 years old. There is also the possibility of a bridge tap on the incoming line. A cherry-picker has been tasked for Friday, so hopefully we are getting it sorted
Once again, many thanks to all who have responded!
iniltous
Recognised Expert
Message 24 of 29
What you refer to as the 'master socket' in photo 1 isn't a socket at all , it's a BT 18 ( block terminal), , you obviously cannot 'plug' anything into it , so it's not a 'socket' ...if the actual 'main' socket wired from here is just a LJU 2 , rather than a NTE5 , it's still the 'master socket', it should have extra components ( capacitor, resistor etc) over and above an extension socket, pics of these are available by searching BT line jack unit. It's a moot point if Openreach are visiting on another matter, but the obvious thing to do is only have 1 (main) socket wired from the BT18, removing any other wiring to any other 'sockets' , and convert the main socket to a proper master socket ( NTE5 type)...if OR don't do this, you only need 2 wires connected from the BT 18 to the A and B terminals of the master socket, and your router plugged in here will achieve the best sync .
ARWalker
Message 25 of 29
Update.
BT engineer called back today. They have repaired the fault at the pole, having to replace some sort of junction box which had corroded and filled with water.
The LJU upstairs was still absolutely fine, and remained in situ. The extensions have since been removed and the problem appears to have beeen rectified.  The connnection was reset by the engineer, and we just have to wait to see what spped we get when the line stabilises.
Once again, many thanks to all who have responded.  Merry Christmas!
Message 26 of 29
Thanks for the update, hope it stays ok, no reason for it not to.
Message 27 of 29
That's good. Can you post stats from smart hub to compare with previous set please
ARWalker
Message 28 of 29
Here's the stats
Product name:
BT Hub 6A
Serial number:
+084316+NQ71532136
Firmware version:
SG4B1000B316
Firmware updated:
28-Jul-2017
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 3 Hours 27 Minutes 2 Seconds
Data rate:
10.00 Mbps / 55.00 Mbps
Maximum data rate:
19036 / 61961
Noise margin:
12.4 dB / 7.9 dB
Line attenuation:
17.3 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
4170 MB Uploaded / 4911 MB Downloaded
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-C9H3
2.4 GHz wireless channel:
Channel 6
5 GHz wireless network name:
BTHub6-C9H3-5
5 GHz wireless channel:
Channel 44
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:28:9A:9F
Software variant:
Boot loader:
7.33.1
Message 29 of 29
What an improvement.
You are are now on the infinity 1 max speed
enjoy
