Newbie
Message 1 of 3
Removing old unused 2nd line
Is it ok to remove an old connection socket and cut the wire at the outside junction box for an old unused 2nd line.  I want to remove the wire which goes round the house to the back room before I redecorate.
2 REPLIES 2
Expert
Message 2 of 3
Re: Removing old unused 2nd line
Yeah, it’s your house and if it’s not being used then go for it.
Distinguished Guru
Message 3 of 3
As long as you are 100% certain that line 1 does not go in that cable.  Expect a large bill from your Comms Provider if you cut the cable if it does.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
