peterwot
Message 1 of 15
Replacement faceplate for master socket
I have a standard NTE 2000 master socket but the faceplate is hanging loose from the wall as I had to connect a dangling ADSL filter direct to a socket behind the original faceplate. It works fine but looks very untidy and now grandchildren on the crawl! I want to purchase and fit a new face plate with two input sockets so I can connect the ASDL filter. Where can I purchase a new faceplate? I have searched google etc without success. Thank you.
14 REPLIES 14
XRaySpeX
Recognised Expert
Message 2 of 15
Re: Replacement faceplate for master socket
For example: ADSL FacePlate Filter
You will no longer need to use a dangly filter as this faceplate is filtered.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
peterwot
Message 3 of 15
Thank you for quick reply (greatly appreciated) but I will need to reconnect the wires and have no idea which numbers/colours  to use.
Wd prefer just to be able to rconnect dangling filter but maybe suitable facepalte is not avaialble.
Help please!
XRaySpeX
Recognised Expert
Message 4 of 15
You mean the wires at the back of the faceplate? So, you must have some extension sockets?
You just connect the same 2 & 5 terminals as you have now. It's a straight forward replacement.
If you have an NTE-2000 it's already filtered & you needn't be using a dangly filter.
peterwot
Message 5 of 15
Thank you and I will let you know how I get on! Much appreciated peter wot
Distinguished Guru
Message 6 of 15
Why did you have to remove the frontplate? Was it causing a problem?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
peterwot
Message 7 of 15
To connect the filter to the test socket as per BT start instructions which was hidden behind the faceplate
Thank you
XRaySpeX
Recognised Expert
Message 8 of 15
So, why don't you just screw it back on?
peterwot
Message 9 of 15
I need (unless I misunderstood the starting instructions)  to connect the filter direct to the test socket but the existing face plate covers it up!
Thank you
Peterwot
Moderator
Moderator
Message 10 of 15
@peterwot the NTE 2000 has a filtered faceplate which means you don't need to use the filter you have connected.  Your phone connects to the socket on the right and the Hub connects to the one on the left.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
