peterwot
Message 11 of 15
Re: Replacement faceplate for master socket
Neil
Thank you
The problem is that my faceplate only had one socket!
Message 12 of 15
I'm not sure I understand what the problem is here. You can just replace the faceplate and plug the filter in there. The test socket, is as the name suggests, just for testing purposes to isolate internal extension wiring when fault finding.
Message 13 of 15
@peterwot wrote:
Neil
Thank you
You can fit one of these, it plugs into the test socket, and screws in position. It works for VDSL and ADSL.
It has a separate socket for the phone and home hub, and an inbuilt filter.
LINDY VDSL2 Microfilter Faceplate
XRaySpeX
Recognised Expert
Message 14 of 15
Then I don't think you have a NTE 2000, as you said in your OP, but an ordinary NTE5A faceplate which just has the single phone socket at the front & which needs the dangly filter to connect the router.
You can replace it by any NTE filtered faceplate, which will have 1 socket for phone & the other for DSL, & you'll be able to ditch the dangly filter except when you need to get to internal test socket. Search Google for "Buy BT NTE Filtered Faceplate" & take your pick.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
peterwot
Message 15 of 15
I am very grateful for all the replies and I now know what is needed. Problem sorted! peter wot
