Message 21 of 25
Re: Scam Calls from BT (not really)
@Compuaccord the info @iniltous and @licquorice  have provided is correct. You can't be charged for a call that you didn't dial. Pressing a number on an incoming call from a potential scammer is not recommended but if you do it won't result in BT billing you for that call.
Neil
Message 22 of 25
Thanks for the confirmation @NeilO
Message 23 of 25
Thanks for that, we can try and beat them at their own game now.
(As a moderator you are fairly official aren,t you ? )
Message 24 of 25
Moderators are all BT staff.
Message 25 of 25
I wouldn't recommend it, never good to poke a hornets nest.
