deejay
Message 1 of 4
Second base station
Hello all
I have a Hudson cordless set with the maximum of four handsets.
I would like two more .
Can I connect  a second base unit to the same line with its own two handsets?
TIA
Dave
3 REPLIES 3
Message 2 of 4
Re: Second base station
There should be no problem with doing that.
Distinguished Guru
Message 3 of 4
Although you will not be able to make handset to handset (intercom calls) between handsets on different basestations.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
deejay
Message 4 of 4
Thanks for the replies.
Good point about the intercom facility Dave. I hadn't thought about that.
Cheers
Dave
