@Keith_Beddoe I have cropped out the phone number but this is what I get form the dslchecker.
Hi @Turch and thanks for posting.
I'm sure we can help you with this. I've sent you a Private message explaining how you can contact the forum moderation team. Check here: https://community.bt.com/t5/notes/privatenotespage. Just drop me over a reply with the details and we’ll check it out.
Cheers
David
Then it says that FTTP is available.
Try calling the FTTP team on 0800 587 4787.
These orders are not dealt with by the normal BT sales team, and that is what is causing the problem, as its your existing copper route records and billing which are incorrect, which CAN be sorted here.
The moderators cannot help with the ordering issue, but the FTTP team will be able to help.
@Keith_Beddoe Thanks for the advice Keith. I have spent about 2 hours on the phone to them between today and yesterday a d actually spoke to the fibre team but on getting the same result in regards to the address issue and order.
Thanks David. Replied now.
I am sure one of the moderators will be able to help. Once the copper routing info is corrected, it should resolve the order issue.
The only problem that may occur, is that when it is updated, the checker may no longer show any FTTP availability at your correct address, it depends on how far the addresses are apart.
@Keith_Beddoe I hope so Keith, Thanks. Obviously on the dslchecker it appears as though we can finally get fibre if its reliable using the phone number alone. When you have been on 1mb for 8 years you will take any glimmer of hope you can🤣
@Keith_Beddoe @DavidM Just a quick update. Having gone the dsl checker today it appears that the FTTP option has now gone. I spoke to a guy at BT yesterday and he said he tested the line and he said that we could get it. Bit confusing but there you go.
