Message 1 of 3
Static noise on line
Hi all.
Since having the bad weather over the weekend my phone line has been having problems. Theres like a staic noise on the line and ive tested the line inside and all sockets have the same problem.
Any ideas on what to do?
Many thanks
2 REPLIES 2
Message 2 of 3
Re: Static noise on line
I would bet dollars to doughnuts that the rain has got into an external manhole or cabinet.    As a precaution  ( and because you'll be asked to do so anyway,  no doubt )  I would try plugging a phone into the internal master socket to see what happens,  although I'd bet the result will be the same.    Other than that,  all you can do is report it as a fault to BT and leave Openreach to do their thing.
Message 3 of 3
I did do a test in the test socket and it was the same. Thanks for the advice 😃
