Semajal
Message 1 of 15
Still getting noise on line, intermittant fault, two engineers have tried. What next?
So I have had problems for a while now, mostly noticable in my ADSL dropping out (provider is BE) however a few weeks back I managed to eqaute this to noise on the phone line. I have a number of times been able to hear crackling noise over the phone line during a quiet line test using an analogue phone plugged into the test socket. Engineers have been round twice, first could find no faults, the second came today and did hear some noise on his initial quiet line test, and one fault was found with equipment. He replaced a connection and the fault didn't show up again. However I am still having the internet drop out, and getting intermittant noise. I have no extensions, and router/filter/all cables have all been switched over. I am slightly at my wits end as there doesn't seem to be anyone who can do anything, who should I contact or what should I do at this point? my ISP have tested everything they can and can also find no faults, but can confirm my connection drops a lot, as well as errors in terms of data loss, implying noise on the line.
14 REPLIES 14
Reed_Richards
Message 2 of 15
Re: Still getting noise on line, intermittent fault, two engineers have tried. What next?
You just have to persist.
If you have enough audible noise on the line for there to be a reasonable chance of a visiting engineer hearing it then keep reporting this as a voice fault until it is fixed.
If not, and you have tried the Test Socket, different routers, cables filters and a wired connection from the router to the computer all to no avail then report it as a fault to your ISP.
Either way you should get a visit from an Openreach Engineer, although they might well run different tests in the two instances.
It might also be worth using a program called Routerstats to monitor your router in case there is a pattern to the Internet drop-outs that you have not yet noticed.
Semajal
Message 3 of 15
I had BE send me one of their routers, which I have been using for the last few days to no avail. Previously had been using a draytek. Currently everything plugged into the test socket, still problems, but of course since it is intermittant it is easy to miss depending on when it happens. I guess I should just keep track, get another engineer round and see if they can put me on a different line.
Message 4 of 15
who do you pay line rental to,
Semajal
Message 5 of 15
we pay BT for the  phone line.
Message 6 of 15
Ok just checking as some ISP's do phone packages as well
try the quiet line test dial 17070 option 2 you should hear no noise if you can then it needs reporting to faults on 151
Semajal
Message 7 of 15
As said though, its intermittant. Sometimes noisy, sometimes fine. I have had noise on quiet line tests and have had two engineers come and find no problems initially, then one test failed, then didn't fail, (although nothing obviously broken was fixed) then it was fine, then still getting noise. I just feel ill keep going in circles, engineers will come and do their best to find a fault, but it mostly won't show up. can I request getting swapped to a different line? (id guess this would be cheaper in the long run as won't keep having to call engineers out to try and fix it?)
Reed_Richards
Message 8 of 15
Your ISP should have a record of every time your router loses its PPP session or Internet connection.  So if you are having problems they can see it (if they consult their records).  If all else fails they may switch you to a different line but I think they will probably want to try a few other options first.
One possibility is that your problem comes from electrical interference from some other device in your house that is transmitted to your router over the mains wiring.  That is why it is worth maintaining your own record of when you get disconnections and how your noise margin varies over time, using Routerstats.
Semajal
Message 9 of 15
Operational statusup  14096
Download bitrate 14096.0
Upload bitrate 1797.0
Admin stateup
1-day retrains 46
Received bytes  6.418474613E9
Sent bytes  2.23097058E8
Sent bytes discarded 9.9934966E7
Received bytes discarded0.0
Loss of signal 23
Loss of frame 0
Severe error seconds 11
Error seconds 598
Failed inits 10
Stats from the provider, this morning I once again got noise on a quiet line test plugged into the test socket using an analogue phone. Above stats are from about a 20 hour period the other day. The current default router I am using from BE is not a default in routerstats, I will have a play around later to see if I can get it working in some form)
Reed_Richards
Message 10 of 15
Try Routerstats Lite; that works with pretty much any router. http://vwlowen.co.uk/internet/files.htm#routerstatslite
