Message 11 of 15
Re: Suddenly unable to make international calls
it was explains more about CPS to you also some people use CPS services to reduce call costs
Nick2008
Newbie
Message 12 of 15
Hi
I found your post whilst looking for a solution that suddenly occurred on my mother’s phone line.
I got her to contact BT they checked the line and found no fault.
We changed her phone , no good
I then got her to get call barring checked out, Nope
BT changed her number in hope that would cure the problem . nope.
the next step they were going to go down was change her line ? But she got through to another technician who asked if he could check her call log and there the problem was found.
A with held number incoming to her from her GP had some how put a BLOCK on out going International calls.
The technician removed the number from her call log and hay ho 2 hrs later she was able to call her brother in South Africa.
Have BT check the call log for a withheld number around the time the problem started .
good luck
pompey1898
Expert
Message 13 of 15
@Nick2008 wrote:
Hi
good luck
You have posted on an over 2 year old thread.  I suspect the gentleman might have got it solved, or perhaps not.
Nick2008
Newbie
Message 14 of 15
didnt see when this was put up by the OP.
i only found it because of the prob my mother had so posted result which may be of some use to someone
amsr
Newbie
Message 15 of 15
Hi, I came across this whilst running into a similar problem: My partner was trying to call me from Australia using Skype and could not.. Neither could I call an Australian landline. However, if used the 1280 prefix, I could call, and he could call me from his mobile. I tried using the phone settings and 1572 and everything seemed to be unblocked, even anonymous numbers. Then I went via the internet to my BT account and I discovered that I had blocking of BT-blocked numbers switched on by default, so I switched that to Allow. Then, my partner was able to Skype me and I could call an overseas landline without the prefix. I hope that this helps, it is a bit bad that BT classifies Skype as junk calls! good luck.
