clarepantry
Message 1 of 3
Telephone Line coming into Bedroom
Hi
My main telephone line, at some point has been moved, and it now comes through into my daughter bedroom upstairs.
I no longer want this as i don't want the internet router in her room.
Can i disconnect the line, take the wire out, and run the cable into the hallway and reconnect into the cable box there?
Any help is welcome.
Thank you
Clare
2 REPLIES 2
licquorice
Message 2 of 3
Re: Telephone Line coming into Bedroom
Yes you CAN, no you MAY not.
Devon_Dave
Distinguished Guru
Message 3 of 3
Only openreach can move the main socket. You could however get an extension socket installed elsewhere and plug the router in there.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
