Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
My neighbours tree branches have overgrown over the BT phone line, with some of the branches hanging over into my property and touching our phone line that comes into our property. I have discussed with my neighbour previously where she advises that the Utility companies are OK with it including BT which I find hard to believe. We do not currently enjoy a good working relationship due to dispute over the cost of a boundary wall, allied from the constant noise from their 6 dogs.
I usually keep my side trimmed back, but have not been able to do recvently due to poor health.
Who can I contact at BT Openreach to get them to survey the tree, and additionally there is a cable hanging down thast needs to be fastened to the post on our property.
I am concerned that it will eventually effect our phone line. I am not presently a BT customer however have been in the past, and may well return in the future.
Solved! Go to Solution.
First of all as this is a BT Retail forum for BT customers there is nothing anybody here can do.
Secondly, Openreach (it is not BT Openreach) will not be interested until or if a fault occurs and only then when they are tasked to fix a fault raised to them by your supplier.
Hi @Carwyn93
Welcome and thanks for posting!
As long as the issue isn't service affecting you can contact Openreach to report damage, health & safety
If you were having service problems you would need to raise it with your provider. As this isn't service affecting, the link above is your best bet.
Cheers,
Robbie
