Message 11 of 14
Re: Trouble with landline
I guess its just giving a single ring that you cannot hear, but is sufficient for the phone to register as a missed call. You will just have to report it as a fault, and say that is still there with everything unplugged.
Message 12 of 14
Yeah, just going to ring them up and then see what they say. Thanks for your ideas tho, big help.
Message 13 of 14
Please post here when it is fixed, so that we know what was causing the fault. Thanks.
Distinguished Guru
Message 14 of 14
Hi, I can't see in any of your posts that you have tried the phone at the BT test point, this is located by removing the bottom half of the main socket, the test point is inside on the right hand side. I suggest you try this before BT visit your premises.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
