Newbie
Message 1 of 3
Unable to set Remote access PIN for BT3570
Despite reading the manual several times, I am unable to set a PIN for remote access of the answerphone.
The manual states that the default setting is "off", but when I try to set a new PIN, I am asked for the current PIN which doesn't exist.
2 REPLIES 2
Message 2 of 3
Re: Unable to set Remote access PIN for BT3570
Bottom of Page 52 of the manual
Change the system PIN
To change some of the settings on your phone, you’ll
need to give your access PIN. This is a four-digit
number and the default is set to 0000.
Newbie
Message 3 of 3
Many thanks!
It would have been helpful if that default PIN had been given alongside the Remote Access instructions, rather than just stating "default is off".  If I hadn't seen your reply, my next step would have been a guess at 1234 or 0000.
