Message 11 of 13
Re: When does a new landline get activated ?
@pompey1898 wrote:
@imjollywrote:
just hope it is not an old take away number
What is a take away number please ?
Fast food outlet where you phone up to order food for delivery
iniltous
Recognised Expert
Message 12 of 13
If the number hasn't yet been routed to your daughters address in Openreach's databases , then although using the phone number to get a speed estimate is usually the most accurate, in this case ( as the line is only part way through its provision process ) using the post code will give a quicker guide to the likely speed , or wait until the line is properly installed....if your daughter is getting line and broadband , then BT should gave already given her a speed estimate.
https://www.dslchecker.bt.com/
Try the post code here
If it's just a case of changing provider rather than moving address, the speed the new provider delivers will pretty much be the same as the old provider speed , providing it's based on the same Openreach product 40/55/80Mb, but if getting 35Mb , the higher 2 products may be pointless , as if the line can 'only' do 35Mb , buying the 80Mb product will still only get 35Mb (download)
Something  to have in mind, is the speed can be less with the new provider in the first few days , but should recover to at least the previous provider speed
pompey1898
Expert
Message 13 of 13
Hi @imjolly ,
Sorry, I thought it was some technical for some type of number Smiley LOL
