I get a call a day from an 0845/0843 number. Is it possible to block all calls from from those prefixes in a couple of easy steps?
Hi @Seyley12, thanks for your question about blocking incoming calls. It's not possible to block all calls from these number ranges. Have a look at Call Protect as that may be of some use to you.
cheers
John
Totally my fault... but thanks for your response regarding landlines.
These nuisance calls are coming through to my BT sim mobile phone (Doh! Sorry, I should have said, although I was hoping that there was a similar system to the known landline version).
Thanks for your assistance though... it seems like I will have to continue receiving these daily calls but it feels like death from a thousand papercuts. I block them one by one, but they continue.
