mikeg145
Message 1 of 5
Why can't I get caller display again?
For some years I have had BT Basic with voice mail/privacy/caller display.
About 2 weeks ago I decided to cancel voicemail and use my handset voicemail facility instead - there are occasions when I want to keep some messages for a long time. When voicemail was removed, I also lost caller display, which I require. I have tried to get caller display back again without success. I even went to the extent of asking for an upgrade to a non-basic calling plan via your 150 number. But your helpful operator found that after entering all my details there was no option to add caller display to the plan. So I did not proceed.
What is the problem with caller display?
4 REPLIES 4
StuartH
Moderator
Moderator
Message 2 of 5
Re: Why can't I get caller display again?
Hi @mikeg145
Welcome to the community, this sounds like something we can investigate for you.
I've sent you a private message asking for some more information.
Stuart
mikeg145
Message 3 of 5
Thanks Stuart.
Have supplied the info as requested.
mikeg145
Message 4 of 5
Hugh, caller display is now active.
My thanks to your and your colleagues prompt actions.
It puzzles me that I had to come here to achieve a satisfactory result.
JohnC2
Moderator
Moderator
Message 5 of 5
Hi @mikeg145  thanks for the update and glad we were able to help you get this fixed. I'll let David, who was dealing with this for you, know it's working now 🙂
Cheers
John
