Newbie
Message 1 of 9
Wireing
I have an older type telephone with Blue,White,Green and Red  wires can you tell me in which sequence do they fit into the telephone plug
8 REPLIES 8
Message 2 of 9
Re: Wireing
@Peewee1
Who provides your phone service?
Newbie
Message 3 of 9
Re: Wireing
B.T. is the line provider
Message 4 of 9
Re: Wireing
Older phones may no longer work on your BT Retail phone line, especially if they do not support tone dialling. Most phone now only have two wires, and are tone dialling only.
If yours has more wires, then it may be an old dial phone which has a mechanical bell and a rotary dial, and has a separate "bell" wire
Newbie
Message 5 of 9
Re: Wireing
Thank you very much for your reply. Yes it is as you explained.So basically it is now just an ornament.
Message 6 of 9
Re: Wireing
Search Google for a pulse-dial to touch-tone in-line converter.
Newbie
Message 7 of 9
Re: Wireing
Thanks for that it sound interesting. I will definitely check that out. Just one more question, is this converter suitable for all phones or do I have to specify that is for the U.K.system?
Message 8 of 9
Re: Wireing
It would have to be for UK usage, as the DTMF tones that are transmitted would have to match the BT exchanges.
Newbie
Message 9 of 9
Re: Wireing
Thank you for your help.
