nik13
Newbie
Message 1 of 2
advice needed
Hi there I need to buy a combination phone of a corded handset with two cordless handset that have the ability to transfer an incoing call from the main corded unit across to one of the cordless -would anyone know if there is a Bt phone that could do this ? It has to be able to call from the main unit to the other handsets.
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: advice needed
Hi. Not really up on the exact latest models of cordless phones but I would say 99% have the facility of intercom calls between handsets. Just a quick suggestion, make yet Tue handsets support caller display, it may save you grief in the future when answering calls.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
