midlife
Message 1 of 8
ansaphone stopped working
my ansaphone has stopped working on the landline and not certain why, the phone rings contiually and the voicemail wont kick in, when I try to ring 1571 it says I cannot connect,.
help would be gratefully accepted
Graham
7 REPLIES 7
Message 2 of 8
Re: ansaphone stopped working
Welcome to this user forum.
Who provides your phone service?
midlife
Message 3 of 8
Hi there
it is BT
regards
Graham
Message 4 of 8
@midlife wrote:
Hi there
it is BT
regards
Graham
Thanks.
Can you please plug the phone directly into the test socket, and see if it still rings all of the time?
midlife
Message 5 of 8
Hi Brian
thank you for your support, I have a different master socket called 5C and there is switch on side I have put the plug into the test within the socket and I rung the landline and there wa no ringing and it appears that the call wasnt going through.
does this make things clearer!!
best wishes Graham
Message 6 of 8
@midlife wrote:
Hi Brian
best wishes Graham
Where was it plugged in when it was ringing all of the time, I assume you mean the phone was ringing, and not just ring tone you could hear when you called the number?
midlife
Message 7 of 8
thank you Brian
I will contact BT and see what has happened, appreciate your time and help
Graham
Message 8 of 8
@midlife wrote:
thank you Brian
Graham
If you hear ring tone, and the phone does not ring, but you can still dial out, then that is most likely a fault in the exchange equipment, which is quite common.
I would check your phone number by dialling 17070, just in case you have a crossed line. That will tell you your number, which you can compare with your own number.
