docyo
Message 11 of 13
Re: appalled by BT
maybe all their lines are down and openreach are not going to them as promised either.
Message 12 of 13
Re: appalled by BT
once a fault is reported to Openreach by a service provider there is no need for a provider to call back as the fault has been reported and is in a work stack to be completed
Moderator
Moderator
Message 13 of 13
Re: appalled by BT
Hi docyo and welcome.
I'm really sorry you didn't get the call back as promised. That shouldn't happen. If you can send me over the details I'll be happy to look into this or you. You'll get the contact the mods link in my profile.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
