sentinel1
Newbie
Message 1 of 4
b.t.phone-bt4600
my b.t. 4600phone is showing the message --LINE IN USE.CALL CANNOT BE MADE. please help.
3 REPLIES 3
Zombie
Expert
Message 2 of 4
Re: b.t.phone-bt4600
Hi @sentinel1 have you tried unplugging all the phones for a couple of minutes and see if that clears the message?
sentinel1
Newbie
Message 3 of 4
Thank you zombie . you're suggestion worked perfectly. i'm really grateful.  thanks.
Zombie
Expert
Message 4 of 4
You’re welcome @Sentinel I’m glad it worked for you.
