Hi, when trying to dial out on my BT3950 cordless phone the "busy" display comes up. I can still recieve incoming calls. Any help will be much appreciated!
Pete
@PeteWatson I see you've changed the heading to sorted, what was the matter. It might help others with the same issue.
Problems like this are normally sorted by one of two things.
Turn off the power to the base unit for a couple of minutes.
Remove the batteries from the phone for a couple of minutes.
