a-d-m
Message 1 of 2
can someone listen in to my calls
I am enquiring about something that happened recently to a friend.
She had been called by someone, a friend, and once the call was finished she hung up, as usual.
She then went to make a call, got dialling tone and phoned someone else.
Later she met the first caller down the street who told her that she had heard her phone call conversation with the second caller.
Is this possible?
Has her phone been hacked or tapped?
Is it illegal to listen in on others calls?
Thank you for any advice.
1 REPLY 1
lnajr02
Message 2 of 2
Re: can someone listen in to my calls
It's possible to have a line fault that would induce the sound between pairs of wires. I would recommend that you ask for your friend to call her service provider to get the line tested, if its BT call 151.
