markduk
Message 1 of 2
cannot make outgoing calls
for the past few months i've been unable to make outgoing calls. so 3 weeks ago i contacted BT and they sent an openreach enginer who told me the exchange and phone line was working fine and that BT have put me on OCB. so i contact Bt and since then they keep promising to fix it but dont bother. 3 weeks later and i still cant make any outgoing calls.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: cannot make outgoing calls
Hi markduk,
Welcome to the forum and thanks for your post!
Sorry you're having problems making calls on your line.  Send over your details so that we can help sort this out for you from here.  Click on my username and under the "about me" section you'll see our contact link.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
