Message 1 of 8
connect bt inspire 1500 cordless handset to bt everyday phone cordless base station
can j connect a bt inspire 1500 cordless handset to bt everyday phone cordless base station
7 REPLIES 7
Message 2 of 8
Re: connect bt inspire 1500 cordless handset to bt everyday phone cordless base station
youar supposed to be able to connect DECT phone
I have done this but with different phones and first was to deregister the phone from it's existing base unit then you should be able to re-register the phone to the base unit you intend to use
Message 3 of 8
there is no "find" button on the bt everyday base station, so how do i connect to the inspire handset?
Message 4 of 8
i typed a reply and then it was wiped when the site says that  i must login to reply....when not tell you to login when you press the reply button or before you start typing...typicall bt! ... anyway, no "find" button on the "everyday" base station so suspect i cannot add another handset. i'll wait for somebody who knows to reply...suspect i'll be waitng a very long time
Message 5 of 8
page 34  https://www.shop.bt.com/content/uni2/documentation/d9r8/everyday_phone_ug_.pdf
this may help
Message 6 of 8
it's all come back to me! ...you cannot de register from the handset that is not on the base, you have to de register a handset from the handset on the/whick is the base...then go to the handset you want to connect and use the "hs config" from the menu to register to the new base by holding the "find" key on the new base. i blame my stupidity and being old! 🙂 ... all now sorted.
Message 7 of 8
Message 8 of 8
i, yet again blame my age, as i read the instructions but only thought (wrongly) that the "find" button on the everyday base was only used to ring the other handsets...i should have read the instructions fully! Many Thanks
