cikin
Message 1 of 4
dial out ok, can only receive calls from mobiles not landlines after sky to bt swap
Signed up to full BT package early October coming over from sky, no phone 1 week, no broadband  3 weeks, had to have a temp number as BT could not get my number, after nearly 4 weeks and at least 30+ phone calls to get any sense on what is happening I am now at the point where I have my old number, can dial out fine, broadband is working fine, can dial the phone ok from a mobile no problem,  but any incoming calls from a landline cannot be made, message of 'number not obtainable' or similar is heard. I have had this line for no problem for 15 years until I came over to BT. Have also had a temporary number on this line whilst waiting for my number. Called BT today to report the issue, the indian guy was not receptive to what I was saying and wanted to get an engineer out, I told him I dont think a visit to my home is needed, surely the issue is at the exchange and the number has not ported across properly somehow, was told I would have to pay £129 if no fault, of which I am certain there is no fault at my home. How do I resolve this?  I dont want to waste anymore time waiting for an engineer.
The whole customer service of BT I have found appaling, nobody ever calls back when they say they will or seemingly take ownership, sick of all the hassle to be honest.
Any advice on how to resolve my phone issue is appreciated.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: dial out ok, can only receive calls from mobiles not landlines after sky to bt swap
@cikin I'm really sorry about the problems getting your BT service activated. That definitely sounds like a porting issue and shouldn't require an engineer visit to sort the adviser should have spoken to the Openreach number portability team in this instance.
If you need any help please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
cikin
Message 3 of 4
Thank you Neil I did as you requested last weekend ,  hopefully soon it will be resolved
Moderator
Moderator
Message 4 of 4
Just to let other members know that this issue was resolved by changing the telephone number for the OP.
Cheers
John
Community ModeratorJohnC
Kudos”Kudos”
