naoma
Newbie
Message 1 of 9
eldehrly mum cut off in error. lives alone. emergency fall alarm now useless nobody will help.
Spoiler
My mum is 85 has light dementia very wobbly on feet lives alone in rural location. moving to live with me on 10.1. Did home move order with datr for cut off 10.1 I HAVE CHECKED my order. it is correct
thry cut her off yday. she is housebound and has an emergency call system which of course does not work either now. If she falls or needs help she cant get it. the error is bt but they say cant rectify till mon when management team is bsck at work. someone should be avail to sort this now. i just want the line reinststated..my no is *********. Im Hazel the dsughter and my mum is mrs m bruce. if anything happens to her you will be liable. please sort this it is an emergency. thanks h
8 REPLIES 8
Distinguished Guru
Message 2 of 9
Re: elderly mum cut off in error. lives alone. emergency fall alarm now useless nobody will help.
Hi. Can I suggest that you remove the phone number and vol reference from your posting we this us a public forum for all to see.
At this time of the night your best bet is to get back to the faults dept on 151 or 0800 800 151 and try to get them to raise the job as a welfare case, quoting what you have told us.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 9
I have flagged to the mods and they will contact you.  as already said please delete phone number and vol ref number
naoma
Newbie
Message 4 of 9
Explained.but they say can only get authoridation from management team...9-5 m-f tho
naoma
Newbie
Message 5 of 9
Mods? No contact yet.thanks anyway.h
Distinguished Guru
Distinguished Guru
Message 6 of 9
Once the immediate issue is resolved you might like to consider the Priority Fault Repair Scheme for the future.
Mods is jargon for the moderators who oversee this forum and provide appropriate assistance. Don't know their duty hours but it's not 24/7.
By the way your phone number still appears in your original post.
Community Manager
Community Manager
Message 7 of 9
Re: eldehrly mum cut off in error. lives alone. emergency fall alarm now useless nobody will help.
Hi Naoma,
Welcome to the forum.  I am so sorry for all the problems that you are having with BT.  It was good speaking with you this morning.
I will be in touch later on today to discuss further.
Cheers
Sean
Community ManagerSeanD
Show your appreciation!
Kudos”Kudos”
MonicaJ
Message 8 of 9
I hope the mods came to the rescue and sorted this out - shocking description of initial customer support leaving someone vunerable at risk.
dorkus
Newbie
Message 9 of 9
I know the feeling well, same problem, they really need to get their act together
