jac57
Newbie
Message 1 of 7
elderly relative with emergency car button- fault on line
My 90 yr old mother has a CareCall emergency button and has a fault on her phone line - I have reported it via BT automated
service, and was informed it could be 3 days !
Her Call button will not work during this time and she lives alone and cannot use my mobile phone - is there anything I
can do????
6 REPLIES 6
Message 2 of 7
Re: elderly relative with emergency car button- fault on line
Unless she is registered as a high priority customer, three days is the normal repair time. It could be less than that, depending on where the fault is.
jac57
Newbie
Message 3 of 7
Thanks - I have just called the auto service again thay say an engineer will respond to the fault on the 19/1/12-
this is longer than 3 days!
Distinguished Guru
Message 4 of 7
Unfortunatly the 3 days mentioned are 3 working days. Weekends not included.
toekneem
(EASBF)
plainview
Recognised Expert
Message 5 of 7
Phone the faults helpdesk on 0800 800 151, explain the situation and ask if they will raise a Welfare with Openreach.
Also ask the advisor to post you or your nan a free priority repair leaflet for future reference.
Message 6 of 7
There is a document here which explains the priority care service.
http://www.bt.com/includingyou/assets/downloads/FreePriorityFaultRepair.pdf
jac57
Newbie
Message 7 of 7
Many thanks - contacted the number, spoke to an advisor who raised the Welfare issue and it should be back on by
Monday night (16th).
