cliffuk
Newbie
Message 1 of 5
extension line fault
Hi, I have installed a new phone extension line from my BT master socket. It works for a while & then the. I loose the line. When i remove the bottom of the master socket box & test throught the test socket all is well again until I put it all back together . The I get "no line" again. I have replaced the bottom of the master socket , thinging this was the problem again it works for 2-3 days then I loose the line again
 Any suggestions please?
4 REPLIES 4
Message 2 of 5
Re: extension line fault
Leave it plugged into the test socket for a week and see if it fails, I assume that you have your extension plugged into the front of the master socket at the moment?
cliffuk
Newbie
Message 3 of 5
No I wired it to connection 2 & 5 in the base of the master socket. I have had to disconnect the extension
Message 4 of 5
Fine, it is connected internally to the phone socket and pins 2 & 5.
Keep it plugged into the test socket, and see if it still fails.
Also, try a different phone, in case its an intermittent fault within the phone, or its connecting cord.
plainview
Recognised Expert
Message 5 of 5
Reconnect your extension and run a line test on this site, your extension socket may have a loop condition, aka short on it.
