Mara
Message 1 of 5
faint landline is back! pls help
Hello again .Few weeks ago the faint landline problem of my friend Val has been.solved quite quickly without sending engineers out.
But it's happening again.. 2 days ago the same landline is faint again. I tried her phone and hard to hear who's speaking on the other end... So same old problem. Could you please help .thank you. .
I've sent OlgaC a private msg with Vals landline number
4 REPLIES 4
SuperSajuuk
Message 2 of 5
Re: faint landline is back! pls help
The mods do not deal with queries via private message, so your PM to Olga will just get ignored and likely deleted.
Have you tried another phone, preferably corded?
Community Manager
Community Manager
Message 3 of 5
Hi Mara,
Sorry to hear the fault has reappeared Smiley Embarassed
Olga will not ignore your private message and you will get an answer but for any service related issues we would need to take this offline to our email queue.  Could you please click on my username (SeanD) and under the 'About me section you will find our contact link.  Click on this and fill in all the details, this would be the details of your friend Val.
Cheers
Sean
Community ManagerSeanD
Show your appreciation!
Kudos”Kudos”
Mara
Message 4 of 5
Hi Sean. The landline phone is corded...original BT corded phone. 🙂
Mara
Message 5 of 5
Ok I'll do as you asked. Many thanks SeanD
( sorry supersajuuk... I got names confused... It is a corded landline phone . Thx u
