philipw
Newbie
Message 11 of 12
Re: help wit setting up caller display
Thanks. The facility is working. I called BT (via 151) and they said all I had to do was dial "*234hash" and it worked !
Thanks for your help
Distinguished Guru
Message 12 of 12
No probs, don't forget my starSmiley Wink
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
