gutted
Message 1 of 2
noisey line again
i have infinity 2 installed  3 months now and it has been nothing but trouble anyway i have a noisy line what comes and goes every week and if it rains more often this has been happening since the install i have had 2 engineers come out and check joints but found no problems all wiring in the house has been checked and bt says no fault on the line has been found but yesterday as i called the call centre again the line was terrible i could not hear what they were saying because of the noise so they phoned me on my mobile and done some more line checks and said not fault found even thou i could not hear what they were saying i even bought a corded phone and still the same any help would be great  Thanks
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: noisey line again
Hi gutted,
Thanks for posting. Sorry you're having problems with the line. I can help with this. I'll need to run a few tests so can you drop me an email with your details?You'll get the 'contact us' link in my profile.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
