mickle75
Message 1 of 3
permanent witheld number
 can someone help please, I have contacted BT several times to remove the permanent witheld number feature but still it remains. I can see that other people have had the same problem but I can't find the solution.
thanks
mick
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: permanent witheld number
Hi @mickle75,
I'll be able to help you with this. Please can you send me in your details using the "Contact The Mods" links found in my profile?
PaddyB
Moderator-Retired
Message 3 of 3
@mickle75
Thanks for speaking with me. I am glad everything is sorted and your number is now showing when you call out. I will mark this thread as solved now Smiley Happy
Thanks,
OlgaC
