brujikucru
Newbie
Message 1 of 3
phone line still crackling
hi, i got a new hub sent after i checked all other options, it has fixed the bb issue but the line is still very noisey and crackles all the time, i have done a quiet line test and all is fine, i have replaced all the wires/cables tested the socket plugged everything in unplugged everything etc no luck?
sometimes when the phone rings the hub seems to reset its self? the lights all flash orange then go back to blue?
any ideas?
2 REPLIES 2
Message 2 of 3
Re: phone line still crackling
have you tried changing filters they sometimes fail
Message 3 of 3
Is it still noisy with the home hub turned off?
