Message 11 of 12
Re: "Spoof" Number Blocking
@RobFletcher
Thanks for chipping in, which is why I mentioned you, I hope you did not mind 😉
I am sure that @RichardGillis  will find it helpful, provided he has access to the account via MyBT.
Its going to take a little bit of work to start with, but it seems to me to be the ideal solution. I am assuming that unwanted outgoing calls are not a problem, as that would need another solution like this https://btplc.com/inclusion/ProductsAndServices/Nuisancecalls/Outgoingcallcontrol/index.htm
pompey1898
Expert
Message 12 of 12
Hi @RobFletcher ,
A big round of applause for your usual advice for those that need something better than straight Call Protect but can't handle call clocking phones.  WELL DONE YOU !!
