donmaico
Message 1 of 7
unable to set pin number on BT 8610
I recently bought a trio set but when I go to Call control it asks me to set up an Access  pin number. I press ok, then "set pin" which i do( 4 digit), then press ok but where it says "Confirm new pin" there is nothing on the screen that will let that happen , just "back" to the bottom right hand  side. I have tried various buttons and nothing happens. Is the phone faulty?
6 REPLIES 6
Message 2 of 7
Re: unable to set pin number on BT 8610
Hi @donmaico
What happens when you confirm the PIN by keying it in and then pressing the OK key?
donmaico
Message 3 of 7
it says "Confirm new pin" but there is no way i can do that, no option or button i can press other than back
Message 4 of 7
Hi @donmaico
So the number buttons don’t work? You may need to call the product help desk. You will find the contact details on the BT8610 product page.
http://bt.custhelp.com/app/answers/detail/a_id/55305/~/bt8610-advanced-call-blocker
Message 5 of 7
Hi @donmaico   So I am understanding you. You have created a four number PIN, (e.g. 1234). The screen then says “Confirm new PIN”, so you key in 1234 (obviously key in the actual PIN) and then OK and nothing happens.
donmaico
Message 6 of 7
I assume there should be an "OK" showing on the bottom left hand side of the screen  opposite "back" but there isn't
donmaico
Message 7 of 7
sorry yes i didn't re key the pin . Just assumed i would need to press "OK" .Many thanks for that
