Do you mean
Newbie
0
Accepted Solution
Access to Hub Manager
Hello folks
I recently had to rest my PC to "factory settings".   Since then I have been unable to access my hub manager or the bt home hub link.   I cannot find a way to restore the icons I originally had when I installed my home hub 2.
I have no trouble accessing my broadband, this still seems to be working OK but I want to make some urgent changes to my profile/settings.
I hope someone has a few words of wisdom.   Many thanks.
Re: Access to Hub Manager
hi all you need to do is enter 192.168.1.254.into your web browser address bar and you will be able to access your hub manager you do not need the desktop icons to enter it
If you want to say thanks for a helpful answer,please click on the Ratings star on the left-hand side If the reply answers your question then please mark as ’Mark as Accepted Solution’
Distinguished Guru
You can set the address given by John as a Favorite/bookmark for future use.
You can click the white star next to this message if you think it was helpful.
Thanks for this. All hub versions are constant with the address of 1.254 right?
Distinguished Guru
Yes.
