Do you mean
0
Accepted Solution
BT Home Hub V 3.0
Hi activated my broadband account yesterday and installed the HomeHub v3.0 box.  Have managed to connect 2 Laptops wireless and a wired PS3 connection.  Problem is I cant connect my desktop PC using a wired connection.  on connecting the ethernet cable the response is unidentified network no internet access.  Before yesterday I was using a netgear router with no problem I am using W7 and the network controller is NVidia nforce card - Question is does anyone know if this hub has issues with wired connections?
0
Re: BT Home Hub V 3.0
did you try all the ethernet ports on the back of the HH3?  is your network card driver up to date?
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
0
Thanks for the swift reply - PS3 is working on a wired connection, also tried swapping round the ports in case one port was down but no success - driver is nvidia nforce net controller and worked fine with my netgear router yesterday
Distinguished Guru
0
Have you ever set your desktop PC to have a static IP address?
Connect it back to the hub
open the command prompt (cmd), then type ipconfig
Check the IPv4 Address, what is it showing?
-+-No longer a forum member-+-
0
IPCONFIG ipv4 address is 169.254.218.233
Distinguished Guru
0
There's your problem
back to cmd, then type ipconfig /release, then ipconfig /renew
then see what happens...
0
response to ipconfig/renew is windows ip configuration
is that what you expected?
0
oh dear response an error occured while renewing interface local area connection : unable to contact DHCP server?
Distinguished Guru
0
No...
Open Device Manager (start, type device and look for it)
Then Network Adapters - is there a yellow exclamation mark?
If there is, you may need to reinstall and or update the driver
Distinguished Guru
0
[ Edited ]
Try going to Network and Sharing Center.
Click on Change Adapter Settings.
Right click the local lan connection icon and select Properties.
Select Internet Protocol Version 4 and then click Properties.
Delete any numbers in the IP address
Click to select to Obtain an IP address automatically.
