Do you mean
0
BT Hub 3 Wireless Problems
[ Edited ]
We have the BT Hub 3 with BT Infinity and are having problems with it.
- Our wireless printer constantly loses connection and has to be turned off/back on to solve it.
- Every now and then the router loses WiFi connection. Computers can no longer connect to it - the Windows error is that the security settings on the computer don't match the router. The only way to solve it is to do a full reset (paper clip into the button on the back, not the restart button on the side).
Are these known problems? The second problem is much more common when more computers are connected (about 6 or 7).
Edit: I should probably add that we had no problems with the previous HomeHub (which we used after getting two faulty BusinessHubs).
Re: BT Hub 3 Wireless Problems
This link may offer you some help http://forumhelp.dyndns.info/wireless/wirelessmenu.html
If you want to say thanks for a helpful answer,please click on the Ratings star on the left-hand side If the reply answers your question then please mark as ’Mark as Accepted Solution’
0
Sounds like the problem is that the Hub 3 is not good at multiple wireless connections. Makes is rather pointless for a business broadband package.
I'll look at buying a compatible router.
0
if you are a business user then I suggest you try the business forum as this forum is for BT residential customers this is the link to it as you have different support options http://business.forums.bt.com/t5/Broadband-and-internet/bd-p/Broadband
