Do you mean
Newbie
0
Accepted Solution
Blocked website?
Hi, I'm trying to access www.habbo.com but the page doesn't load and instead this error message is displayed;
Oops! Google Chrome could not find www.habbo.com
Try reloading: www.­habbo.­com
I've tried accessing it through Firefox and the same message is displayed. I've cleared my cache/cookies all to no avai.
A few other people I know who are with BT are also having the same problem. I also tried to access the site through a proxy and that was successful, although I couldn't get past the log in page due to a proxy not supporting flash.
Has BT blocked this website?
Expert
Re: Blocked website?
Will not load for me either but does work if using a VPN tunnel.
Recognised Expert
0
[ Edited ]
It does appear to be blocked by BT. The site is up.
Newbie
0
Hi, thanks for your input, guys, I just want to put a couple more websites to you and see if they have been blocked aswell..
www.last.fm
www.kotaku.com
They're all showing the same error messages and can also be accessed through a proxy but I don't really understand why any of these websites (www.habbo.com included) would be blocked by BT?
Can somebody, perhaps a BT employee shed any light on this?
it may be a routing error
If you want to say thanks for a helpful answer,please click on the Ratings star on the left-hand side If the reply answers your question then please mark as ’Mark as Accepted Solution’
Expert
0
Same again with your other sites :smileysad:
Expert
0
P.S. will work through the opera browser.
Newbie
0
Hi John, is there a way to fix the routing error? Or is it a problem on BTs side? I have to remind you that I'm not the only person having this problem.
Newbie
0
dgilbert2, I installed Opera and it still isn't working
it could be within the BT network or indeed out side it without trace routes it is hard to tell
