Do you mean
Newbie
0
Can i connect to xbox live using my bt open zone wifi spot?
i know i will have to bridge the connection with a ethernet cable from my xbox to my laptop but i just cant seem to connect to xbox when i do this.. i have done so many different things and i just wanted to know if it is possible or not so i can put my mind to rest.
I was hoping to be able to use my xbox online through my bt wifi openzone spot. any help anyone please?
a step by step solution would be great please. thank you.
Roger.
Re: Can i connect to xbox live using my bt open zone wifi spot?
Unless the Xbox has a web browser where you can login to BT Wifi, then you are not going to be able to establish an Internet connection.
If you enable Internet sharing on your laptop, then you may be able to connect the Xbox using a cable, but you will still have to login to BT wifi on the laptop, and you will get disconnected every two hours.
Much easier to use your main BT home hub SSID, or an Ethernet cable.
There are some useful help pages here, for BT Broadband customers only, on my personal website.
BT Broadband customers - help with broadband, WiFi, networking, e-mail and phones.
See this link on how to connect your xbox through your computer.
http://support.xbox.com/en-GB/xbox-live/connecting/win-computer
As Keith has said you will then need to log onto to BTWifi.
The connection might not be fast enough for gaming though.
Newbie
0
[ Edited ]
I know this is an old thread, but yes it can be done.
I posted a video on youtube showing the steps involved. Some technical knowledge is needed, using a virtualization solution such as Virtualbox, VMWare Player (free), or similar.
http://youtu.be/QKP07Cks22E?list=UU5A0LCZ4HuWPR8ATBc-5jaw
Because the BT browser login is required to enable internet use, this means that Xbox consoles have no way of authenticating.  There is a setting in Xbox that allows you to 'take over' the identity of another device that has already logged in to BT Wifi Openzone.  The below steps outline a method that makes use of this information.
  • Start a virtual machine that has a web browser
  • navigate to btopenzone.com
  • Login (be sure to select whether you are a Fon customer)
  • Note the MAC Address of your virtual machine (Virtual Box steps below)
  •      Right-click the network icon of the virtual machine
  •      Choose Network Settings
  •      Turn off the virtual machine
  • Start your Xbox, and go to Settings
  • Go to Network Configuration
  • Connect to the BT Wifi Fon Openzone network
  • Go in to the network configuration
  • navigate over to the Additional Settings
  • press down, then A to open the Advanced Settings
  • Enter the MAC Address you noted, and press Done
  • After 1 or 2 tries, you should now be able to connect to Xbox Live through the BT Wifi Openzone
Newbie
0
I have tried all these steps. But my xbox says a have a mtu problem and wont load fifa. I had a strange method what got my mtu working. I connected to hotspot and changed the mac to the mac of my andriod device. Then i connected to my partners mobile hotspot and reset the mac.. i reconnected to the bthotspot and it allowed me to play fifa with 100% connection.. no delays or lag. Can anybody tell me why this happened and why wont it let me do it again?
